Is a door adjustment a DIY job?
My rear door on the passenger side appears to not have a tight fit and often
rattles/make noises. Is there a way for me to adjust the fit so it's a little tigher
when closed?
when closed?
2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
Piece of cake. Loosen the door catch affixed to the body (only loosen, no need to completely remove the fasteners) and adjust as necessary. Don't overtighten / strip.
You can even use a lead pencil to make markings so you maintain the vertical setting and only adjust it horizontally.
