nav not working.
Old Apr 17, 2009 | 11:55 AM
pointman's Avatar
a car that can't do the throttle reset.
nav not working.
morning... nav works flawless. Two hours later, not so much. The nav shows an arrow, but the display is showing no roads. I have a signal strength of about 3 or 4 satellites. Radio works fine, the nav keys all work... but it can't do actual guidance or show any map.
Anyone run into this before? Antenna is on tight.
Old Apr 17, 2009 | 01:59 PM
rockjock's Avatar
I DON'T COME HERE ANYMORE
Check the display settings in the nav menu-they are turned off (you can turn on/off POI's, roads, ect ect).
That-or you have in fact found the middle of no where.
Old Apr 17, 2009 | 02:48 PM
pointman's Avatar
Settings are same. I can't understand why all of a sudden it would go to poop. Antenna is on sturdy, and completely dry. Haven't had rain in a bit.
Old Apr 17, 2009 | 03:36 PM
rockjock's Avatar
If its german, and electronic, it will, at will, change settings for you
