Is SC Clutch supposed to spin at idle?
Code3 SC Pulley BTW.
Air is being sucked in when that air hit the rotors it causes them to move in turn spinning the clutch the air that is coming in is not fast enough to make any boost, its when the clutch is engaged that it spins fast enough to start sucking air and ramming it into your engine.
Its kind of like a windmill effect. its just the air thats moving the rotors not a mechanical force. Or say like a fan in a window that is off just blowing in the breeze.
Regarding your vibration. Can you hear it or feel it? Does it stop when the SC is slowed using friction? or does it remain? If it is still audible, take a length of rubber hose, with engine idling and taking extreme care to not get it into the pulleys or belt, listen to each pulley bearing and you will likely find one that is making a racket. I ended up replacing both my SC pulley bearing and the middle idler pulley and am about to replace the top idler as well. Those all take a beating but are cheap and easy to replace. Better to spend a little to replace as end up stranded somewhere. Usually the SC internals do not go bad, but as Hooley painfully knows, that is not 100% true.
Irish
