Diverter valves installed
Former Vendor of MBWorld
C55,SL55,C63
We just wrapped up a diverter valve project on my C55's supercharger. My car seems to shift a bit better. Not sure its from having a supercharger thats working or if the diverter valves. Here is a picture of the new setup. Kinda but we felt it was needed.
C55,SL55,C63
Not to mention after 100 trys to delete cookies and what not it still logs me in as hooleyboy if i click refresh.
2003 porsche 996 turbo
future projects for hooleyboy! dual cai for slk32 larger h/e that wont break the bank! a new and exciting pulley setup for the 32's . something that wont kill the crank and works!
oh yeah an ecu tune that doesnt need a second mortgage to install!
C55,SL55,C63
My supercharger is engaged all the time and there is not way to stop the car from boosting or to let off any of the boost. This allows air in the surge tanks when under vacuum to be routed back into the supercharger. when i step on the gas the valves close and boost happens. As soon as I let off the gas the throttle body closes and the valve open.
The end result is more linear throttle response, Safer boosting, and maybe better gas millage. Also the car feels so much stronger. it was 105 degrees out any my but dyno told me the car is pulling harder. Thats was with the AC blasting.
http://www.streetracersonline.com/ar.../turbo/bov.php pretty much a blow off valve with a different function
Do you still get the pshhhhhh sound? or no because it is going back in?
