Suspension Torque specs
Old Jun 12, 2009 | 07:58 PM
spr's Avatar
spr
Anyone know the torque specs for the suspension attachment points f/r including sways and rear subframe? I can't find my WIS. I want to go around and make sure everything's tightended properly as i hear a washer rattling noise from rear and thunking for right rear over bumps-
It seems like Front struts are 110nm at strut and 60nm at tops. What about front arms and sways?
4 Rear subframe bolts?
4 rear arms and lower control arm?
Rear sway?
Thanks in advance,
Sean
Old Jun 13, 2009 | 08:58 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Been chasing down some unusual noises on mine of late. Perhaps these will prove at least somewhat useful.
Old Jun 13, 2009 | 09:05 AM
splinter's Avatar
Super Moderator
Part deux. They’re also applicable for the C55’s W209-derived hardware.
Can’t vouch for your Black Series’ retrofit specifications though. :)
Old Jun 13, 2009 | 09:31 AM
Panzerknacker's Avatar
GL 350 Bluetec
I always tighten everything to the universal german spec.
Gutentight.
Old Jun 13, 2009 | 04:12 PM
spr's Avatar
spr
Perfect thanks man. BTW everything is loose! *******s never torqued the stuff down. The subframe bushings were at 40nm! More black series parts go in- about half way done, just have to get stuff pressed.
Old Jun 27, 2009 | 11:55 AM
spr's Avatar
spr
What are the settings for the strut carrier to wheel carrier? Also what are settings for cross strut at wheel carrier? F caliper 6 piston or 4? steering rack to carrier?Thanks man.
