Now it's time for new pump
Old Jun 14, 2009 | 09:31 PM
Bao_Amg's Avatar
C32 AMG, Sti, FIT
I'll pick the best and the easier to install.......
Johnson CM30 or Ford?
Expense is no matter
Thank for ur advices.
Old Jun 14, 2009 | 09:47 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
If expense is no matter than the renntech shaft driven pump is the way to go, but thats $$$$$$.
The ford pump is the same as the stock pump isnt it? both Bosch?
Old Jun 14, 2009 | 10:22 PM
320 dreamer's Avatar
2003 porsche 996 turbo
the johnson pump requires you solder the old plug to the new wires. then tap a hole in the mount base to use the cm30 bracket.
the ford pump requires you swap the end of the pump old with new as the hose diameters are different. also need to swap the plug end. after doing all this you still have a pump that will fail somewere between 1 mile and 40k!
89$ for the ford and 149 for the johnson.
having said all this if you dont increase the size of the h/e neither pump will adequatly cool the s/c. check out waldig's threads on the srt-6 forums . the motor is the same as yours.
Old Jun 15, 2009 | 03:36 AM
DL_AMG's Avatar
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
agree. I stick with $89....since the car is getting slower everyday (when new cars comes out). Time to upgrade to GT-R.
Old Jun 15, 2009 | 10:39 AM
ML500K's Avatar
C32 '02
I got the new updated pump part no. A000 500 03 86, supposed to be an "improved" pump. YMMV.
