FS: W203 - Fog Light (driver side)
Old Nov 25, 2010 | 02:35 AM
moosejaw's Avatar
none
oh then the topic has changed then?
Old Nov 29, 2010 | 04:17 PM
ricecooker713's Avatar
C63 E63
Originally Posted by spr
Did the bulbs fit the harness?? I got a set of depo ones and they had H7 bulbs that had spades that were too wide?? Help? I looked in MB C55 manual and says HB4 bulb for replacement. Check photo the spades are clearly too wide for the H7- Any advice appreciated as I need to get a set yesterday!
hey SPR
on the c55 the foglight bulbs are H7s, from the factory the car comes with an adapter harness that coverts the plug your holding to H7. hope that helps, i think i have a set of harnesses that came with the foglights you sold me a while back on my other s/n. let me know
Old Dec 1, 2010 | 02:20 PM
spr's Avatar
spr
Ah, thanks! I ended up making one as well. Thanks for the clarification!
Old Feb 28, 2011 | 10:21 PM
iceback's Avatar
2002 C32
Originally Posted by vvcobravv
So I got the replacement fogger.
Its amazing that MBUSA would try to charge $255 for this... Its exactly the same!!!!
I ordered the replacement fog from Amazon, just typed in Hella 90mm fog light and it came up for $45.
I attached some pictures of the factory Hella housing as compared to the Hella replacement housing.
Thank you very much for this tip! Replaced both fog lights on my C55 for a grand total of $82. Amazon rocks. Perfect fit - made in Germany. You'll only need a #15 Torx driver and two new zip ties.
http://www.amazon.com/Hella-00858200...8949675&sr=8-4
