Sway Bars for C32?
Jerry
does our AMG sway do the job? im planning on getting H&R coilover, and i was wondering if there is a set of Sway bar out there specific for our cars? eibach?
Jerry
Brabus & Renntech also have sway bars for the W203.
Jerry
The only "potential" problem you might run into is if you have stock projector bi-xenons (2003 models). In such cases the autoleveling sensor will not fit around the front sway bar and you have to get a bigger U bolt for it. But then I imagine the same scenario will present itself if you chose the Evosport one also.
May want to double check just to make sure.
Look at the attached pic and just to the right of #160 it looks like the verticle link (#140) is adjustable. So with a slightly larger U-bolt, the Xenon autolevel sensor should work just fine.
ahh... my bi-xenon... damn it! will bigger U-joint fix it all? any other problems that im gonna encounter?
An even cheaper alternative? Just pry the u bolt out till it fits. Not very elegant, but it should work just fine.
22mm/16mm
Evosport F/R
24mm/19mm
41%/98%
Eibach
24mm/22mm
41%/257%
I'm not going into the equation for bar stiffness but....
Based on math, the rear change on Eibach is a lot more (257%) compared to their change on the front (41%). That aside there are some folks that like Eibach on W203 sedans. BTW, this would add plenty of oversteer characteristic to the chassis.
Evosport users like theirs too. I think you will find the Evosports are a great match for the C32. Eibach is cheaper though.
BTW your diagram doesn't look like the C32.
With Evosport there is no "leveling" issue, it is an "attachment" issue, you might want a bigger u-bolt to attach to a thicker FRONT bar. I certainly didn't, just forced it on a little bit. But you can see Eibach and Evosport are supposedly the same diameter so..... (are you guys saying Eibach's bar is bent at different angles so adjustment is a problem as well as u-bolt)?
Someone with Xenons needs to verify that arm(#140) is adjustable. From the picture posted above it probably is. I don't believe this picture is a C32, but I'm sure all C-class cars will be similar.
did that make sense?
with the rear bars so thick... what is the advantage and disadvantage?
Jerry
so... more oversteer for the eibach sways... what is ultimately better handling? and a better compromise ?
Jerry
I still only have the stock springs and wheels/tires. Even so, the car is flat as a pancake. Can't wait till I get the wheels and cup kit.
Jerry
everyone has their own preferences...but generally...a more neutral car will yield a more nimble and faster car...there are reasons for understeer and reasons for oversteer...
