Dyno Tips Needed
Rage2: I disagree with you with regard to dyno being different from day to day. In my experience of dynoying in the past seven years and of over 1000 cars - if you are using SAE correction numbers you will be very close. Less than 0.1%.
This is very true on a DYNOJET, since there are no variables to play with. In other words you can not change drum mass - it is fixed, or change load by adding brake. The only variables are humidity, altitude and atmospheric pressure. And those are taken care of by SAE correction factor.
In mid90s we ran the same car on three different DYNOJETS. All three graphs overlaid one another. SO one can use DYNOJET numbers from any other DYNOJET dyno for comparision.
Just for the record - 277HP is a bit below average. Of ten C32s that we have now dynoed - the highest is 297HP and the lowest is 266HP. Please search archives for more info.
I've seen cars gain 20hp just from weather conditions on both Mustangs and Dynojets. I guess the dyno operators that I deal with are just idiots and setting things up wrong.
BTW, we see the discrepancies in power on E46 M3s and E39 M5s. M3s vary from 255 to 277HP and M5s from 318 to 342HP. I guess BMWs QA sucks too.
Each car is different, no matter if the motor is built by hand or by a robot.
As far as you seeing the difference from run to run. Sure if you let a car heat soak, engine's DME is going to react by adding fuel and pulling timing. When we run cars on our DYNOJET we monitor ECTs to make sure that the conditions stay the same. If SAE corrections are used than the numbers will be very, very close.
If Carl runs his car again on the same dyno, but now in August at 100F and 90% humidity, he will be below 300HP. If he uses SAE correction for both runs than his numbers will be the same. This is why SAE correction is there in the first place. If your dyno operator is not using them, than you can call him an "idiot".
Carl: Find out who at AMG built your motor! and please let me know who did it so that I can make sure that that they build any future vehicles of mine!
I can't figure out how these Dyno operators are making these dyno runs without the car downshifting. The dyno curve should be starting about 4500rpm not 3800rpm.
Since my prior run was questioned even beyond the SAE correction issue,
torque reading. A little better than I guessed by SAE correcting my prior numbers but right in the ball park. Two consistent runs on different dynos, different days and different operators.
SteveL gave some great tips on running on the dyno earlier in this thread. It is much appreciated as I briefed the Autothority operator before the run. The Curry's guys already knew how to run it from their experience with the SLK32 AMG.
The dyno operator today said he was trying to go down as far on the gas pedal to the point where the button on the floorboard wouldn't be pushed until he got further up in the RPM's. I don't know how soon he was pedal to metal or if the torque curve would look different if he went down earlier.
I too had my baserun on a Dyno 2 weeks ago. The weeks before doing the dyno the weather was really cold and the car felt notically stronger. On the day of the Dyno the weather was unusually warm. After the run we had a look at the filters (stock) and they where realy dirty. I wonder if that would have an impact on the results ?
Eventhough I have acces to 98 octane gas the dyno 'only' showed 279 HP at the wheel.
This week the ODPS kit will be installed and another Dyno run is scheduled about a week afterwards. I will also have the filter changed to high perform filter K&N.
Regards,
BV
