C32 Fuel-pump flow rates
Old 04-26-2010, 10:49 PM
hothbl's Avatar
C32 AMG W203
Originally Posted by ML500K
so can the c32 use a c320 fuel pump with no problems?
The fuel pump flow are different for C32 and C320. If you use C320's fuel pump
with C32 and your car may get lean issue when high RPM.
Old 04-26-2010, 11:13 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
Originally Posted by hothbl
When did you get lean issue?? The ECU can't provide enough fuel when over
130kPa(around 19 psi). This is a limit ! You can use a MAP clamp tool to improve it. I has tested it and working on my C32.
which one did you use and how did you do it? i'm probably pushing 20-22psi
Old 04-28-2010, 08:50 PM
TemjinX2's Avatar
i was looking at retroing a new internal one but after looking it our internal pump diy. It seems like too much work.
I think it might be easier to install a second external fuel pump. I thought about just buying one of those high powered denso fuel pumps for supras and rx7 and adding it as a second fuel pump. It should be more then enough to satisfy our fuel needs.
Would it cause too much pressure if i add a second fuel pump? I know the modded rx7 and supra guys run duel pumps.
Old 04-29-2010, 01:12 PM
hothbl's Avatar
C32 AMG W203
The easy way is use 4.3V ZD to clamp it. 4.3V cheat ECU around 17-18 psi.
You will get lean issue when the map over 4.5V. The best way is clamp MAP to 4.5V. You can use some thing like E-manage BC function do exact setting and keep the max voltage at 4.5V.
You can check my attached picture. Those are my data log.
The Green is MAP, Red is SPEED, Black is RPM and Blue is A/F.
The af1 is before use camp tool. You can see the A/F is lean when MAP
over 130kPa. The af2 is use camp tool. The A/F is slow to lean, but still
under my control. I don't have any ECU tunning. Only do the clamp MAP
and set the fuel pressure at 60psi.
PS: Suggest you install a A/F meter to monitor your A/F after clamp.
If you can use OBDII to check the MAP, it is great.
Attached Thumbnails C32 Fuel-pump flow rates-af1.jpg   C32 Fuel-pump flow rates-af2.jpg
Old 04-29-2010, 01:18 PM
hothbl's Avatar
C32 AMG W203
You don't need add second fuel pump on your C32. We always use a adjustable fuel pressure regulators to increase the fuel flow in Taiwan.
Old 04-30-2010, 10:32 AM
TemjinX2's Avatar
Thanks for the info, I'm really hoping I just have a bad tune and EC can fix this.
After reading the kenne bell stuff, i might just make my own fuel pump booster if the tuning fails. I did the research and I can build my own fuel booster for around $5.
I'm hoping a increase in fuel flow will fix the lean issue or should i really be looking at the fuel pressure rail?
Old 05-04-2010, 11:18 AM
  #32
70GS455's Avatar
1970 Buick GS 455
Attached is the flow graph for some SRT-6 pumps. The external SRT-6 pump is the same as the C320 I think? Also shown are upgrades, the Walbro GSL392, and Bosch 044. And as well, the SL55 AMG pump.
Old 05-05-2010, 03:08 AM
  #33
TemjinX2's Avatar
ok did a custom dyno tune with eurocharged tuning remotely and dynoing a DCperformance.com.
Major props for aaron only charging me 1.5hrs of dyno time when it was really 4hrs.
4hrs of dyno tuning and my power still sucks but i got the afrs down. The fuel line is still junk going from a 10.2 toping out at 12.5 on the last run.
fuel pressure measured 60psi went down slightly to 58psi at 150mph.
So i guess the others are right, the stock fuel system seem satisfactory. I'm going back on friday to try to fix the fuel curves. At least i dont have to worry about my motor blowing up anymore.
current mods EC 185mm pulley, EC headers, code3 intake, code3 heat exchanger, ngk colder step spark plugs.
Old 05-05-2010, 08:01 AM
  #34
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
How are your injectors? Would cleaning them help the AFRs? Is that the last thing left to check in the hardware department?
Old 05-05-2010, 10:01 AM
  #35
AnimC32's Avatar
C32 AMG
Got a fuel pump question. I had the car not start recently (cranks fine but wont start, even cold so it's not CPS/CamPS). MBSM tells me it's my fuel pump but they need to replace the whole fuel delivery system? Like gas tank, pump and lines - $3200. Does it seem right?
Old 05-05-2010, 03:28 PM
  #36
70GS455's Avatar
1970 Buick GS 455
What was your injector duty cycle during these runs? Seems like you need more injector pulsewidth to get that 12.5 down to a safer level. Try to tune for closer to 100% DC in the upper rpms.
Fp dropping down from 60 to 58 would indicate a very mild inadequacy in fuel pump capacity, but certainly not enough to be worriesome, it just indicates that you are just barely starting to exceed the fuel pump's ability. More inj DC% (or pulsewidth) will further exaggerate this as it means more fuel is being demanded.
Old 05-05-2010, 03:35 PM
  #37
Robert AMG's Avatar
Cls63 & C32
Yes our fuel system is adequate, the pressure is not dropping
and the injectors are the same on the E55 where they are flowing fuel to maintain more then 500 whp, so it is all in the ECU, rich loose some power lean get more power, this is our ecu.
Old 05-05-2010, 06:30 PM
  #38
TemjinX2's Avatar
i'm pretty confident the injectors are fine. I have a newer engine with 60k on it. I think its just the tune because i was hitting 15afr and not its 11-12.5afr.
Old 05-05-2010, 06:31 PM
  #39
TemjinX2's Avatar
we have in tank fuel pumps. The dealership wants to swap out the whole thing to get more money from you. You can just swap out the fuel pump. Its around $400 and located in the rear seats. There's a diy on the w203 forum.
Old 05-05-2010, 06:34 PM
  #40
TemjinX2's Avatar
i dont know the duty cycles since i'm not tuning it. It went down to 58psi at 150mph, so i'm ok with that since i'll never hit those speeds on the streets.
I'm going to go back from more tuning and post a update.
Old 05-05-2010, 06:35 PM
  #41
TemjinX2's Avatar
yeah i agree. Even the guys at the shop didn't believe we had the same injectors as the e55 until we uploaded the last tune and go my afrs down to 10-12.5
Old 03-25-2011, 09:20 PM
  #42
WaveyKat's Avatar
Something Slow
Found this info its in chinese tho but still maybe helpful
it the replacement of the pump only and not the Entire Unit!
http://hibruce.pixnet.net/blog/post/24960412
Old 03-25-2011, 09:40 PM
  #43
mikekuriger's Avatar
2010 C63
why not go with an aftermarket fuel pump?
Old 04-07-2011, 12:01 PM
  #44
WaveyKat's Avatar
Something Slow
where can one get this?
Quick Reply: C32 Fuel-pump flow rates
