No sound from Comand?
Old Aug 28, 2009 | 04:22 PM
-PLM-'s Avatar
C32 AMG
Hello!
I´m from Sweden in cold north.
I´ve bought an C32 some weeks ago.
My comand just was quiet when I startad the car up last week. When I checked the fuses (no one was broken) suddenly the subwoofer started work! (It did´nt work earlier). But the usual speakers was still quiet. In tuesday I changed oil in the gearbox at a car repair shop, the mechanics said they also resetted the fault codes. I don´t know if it had with that to do, but both the speakers and the sub worked, later in the evening the sub died. Next day both the speakers and the sub was dead when I started the car up. I once checked the fuse (No 26, sound) and the sub started work again after I put it back (same fuse).
What the **** is the problem? I´ve searched your forum, but could´nt find anything.
I would be very grateful for your help.
Old Aug 28, 2009 | 05:22 PM
willc55's Avatar
2009 Mini Cooper Clubman S
Have you tried replacing the fuse? If it works fine for a while after taking the fuse out and putting it back in the fuse might be faulty?
Old Aug 28, 2009 | 09:40 PM
Tump43's Avatar
2014 E350 4Matic
At one point the HK Comand system in my C55 stopped working -- no sound at all, no radio, no cd but the Nav worked fine. The Stealership just reflashed (reloaded updated software) my Comand and everything worked fine until the center speaker ripped itself apart. I replaced that and everything has been fine since.
Old Aug 29, 2009 | 02:46 AM
-PLM-'s Avatar
C32 AMG
My nav works fine too! Maybe I have the same problem. There are no update to download and install myself?
Old Aug 29, 2009 | 02:48 AM
-PLM-'s Avatar
C32 AMG
It´s not the fuse, but good idea!
