clunking noise on C55 Front suspension
Old Sep 22, 2009 | 08:11 PM
C55LA's Avatar
When I come out from my drive way down turning a bit, there's a clunking noise from front end. Anyone have that problem? Solutions?
Old Sep 22, 2009 | 10:11 PM
Nuori's Avatar
C55 AMG
Worn bushings, ball joints or tie rod ends. What's your millage?
Old Sep 23, 2009 | 12:26 AM
C55LA's Avatar
78k
Changed the bottom something by the control rod
Old Sep 23, 2009 | 09:41 AM
Zeppelin's Avatar
C32
Make sure the nut on the top of the front strut did not come loose. Its the one you can get to from the engine compartment. Also check to make sure the swaybar endlink nuts is tight that connects to the front strut.
Old Sep 23, 2009 | 05:22 PM
C55LA's Avatar
Can I do that by myself? Which nuts are you talking about.? I looked at it there's this rubber cover in the middle and 3 nuts around it?
Old Sep 23, 2009 | 07:27 PM
Zeppelin's Avatar
C32
It would be the one large nut in the center of the rubber cover. If it is clunking then it would be loose to the touch. Sure you can do it yourself, just make sure all the bolts/nuts are tight in the front suspension.
Old Sep 24, 2009 | 12:06 AM
Nuori's Avatar
C55 AMG
Without a proper diagnosis, I would not be messing with suspension based on your question and replies. It's guess work.
It will save you time and money in the end without proper know-how.
