Possible IC Pump failure, question?
Old Oct 9, 2009 | 03:19 PM
mmartore's Avatar
2020 C43
I have 71K miles on what I believe is the original IC Pump. Based on posts here, I think that this is my problem based on loss of power symtoms (no S/C kick in) and it is freakishly slow. My question is, the problem only occurs sometimes, particularly when going up hill. Other times the S/C kicks in just fine. Do you think its my IC Pump? thanks!
Old Oct 9, 2009 | 05:27 PM
Charmer's Avatar
C32 AMG
Yes.
As a safety measure the supercharger will not engage if the temperature reaching the engine is too hot. So if the engine is cold then supercharger will work as normal but because the pump is not working the intercooler doesn't do its job, the temperature increases and eventually exceeds the limit and the engine management system cuts off the supercharger and also limits the revs to 4000.
I'm afraid you need a new intercooler pump. 71k miles isn't too bad, mine gave up at 65k!
Old Oct 14, 2009 | 03:14 PM
Tectite.Metal's Avatar
c32 AMG
what he said X 2. Just got mine changed out under warranty and wow.. what a beast..
