Control Arm Bushing Replacement
Since I still have extended warranty on my car, I took it into the stealership to get them replaced yesterday. Now my car is pulling to the left. Are they suppose to do an alignment after replace the control arm bushings?
The stealership claims they don't have to do an alignment after changing the bushings and want to charge me for an alignment. My argument is that the car was tracking straight before I brought it in, so they must have done something to put the alignment out of wack.
I've found articles on line saying that the toe is very sensitve to adjustments in caster & camber. Apparently adjusting the toe should be the last adjustment when doing a wheel alignment. Any thoughts?
I think I'm going to escalate this matter up to the dealership GM. I can't believe I have to pay to fix something that wasn't a problem before I brought my car in.
