coolant smell coming from engine bay
Subscribe
Nov 11, 2009 | 05:01 PM
Hey guys,
Buying my C32 earlier this year I'm still a noob to MB. I haven't had any problems with my car other that bad seat modules causing S/C shut off, but recently I've been smelling a sweet coolant smell coming from my engine when the car is running.
I've looked for obvious leaks from the hoses, I/C pump, radiator, water pump, but I couldn't find anything noticable. I did put coolant in it about a month ago but it hasn't gone down since then. Also the car runs ok but I there is a noticeable rumble coming from the exhaust that wasn't there before .
From the experienced C32 owners has anyone had coolant issues? Any advice would be greatly appreciated.
Thanks again
Jorge
Reply 0
Nov 11, 2009 | 06:15 PM
intercooler might be leaking.... do you see white smoke when you start the car?
Reply 0
Nov 11, 2009 | 09:09 PM
No, no smoke coming from the back. That's what I was thinking might be the next thing I would check. Does it sit right under the S/C and what would be easiest way to check it?
Reply 0
Nov 13, 2009 | 04:42 AM
Jack the vehicle up, and take off the under-body front skid plate. You will be able to see everything looking under the vehicle. Also look for fluid on the top side of the skid plate.
Reply 0
Subscribe
Currently Active Users (1)
