Parts are needed for this winters mods
Old Nov 11, 2009 | 05:35 PM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
I am trying to look ahead to see what the needs would be for small parts related to engine mods done over the winter months. I am thinking the next step beyond the current bolt ons (ie headers, exhaust work, Pullies. TB upgrades & suspension). I thought that there might be a need for engine related components to go along with cylinder head port and polish and little more aggressive cam shaft grind that would not effect daily drivability. So I looked into titanium valve spring retainers which are about half the weight of the current hardware used by Mercedes Benz. 18.61 grams vs. 10.22 grams. They are lighter, much stronger. I checked pricing Comp Cams which is around $19.20 per, Manley is $14.75 per, and I can deliver from a World manufacturer a $14.25 per. You Need 32 for a V-8. The other hardware part I was thinking about was another run of PTE cams for N/A motors C55's and special small run of cams for the C32 kompressor. Both of these cam grinds would have a reasonably smooth idle at the 600 RPM mark vs. the standard 500 RPM. All would be avalable for your local tuner to install or a DYI
Cheers ___PTEngineering
