02 C32 70k New serpentine belt?
.I did some research and found this belt from autohauzAZ.com:
http://www.autohausaz.com/search/pro...m_term=8PK2902
visually check your belts to see if they're cracked or something's wrong with them.
your issue could be the throttle position sensor on the pedal OR even the s/c clutch pack. might not even be just the belt slipping.
http://www.parts.com/oemcatalog/inde...id=67&siteid=2
I want to be sure that it is the right part before buying it. I will have to call them and talk to them more about it.
Also, my sc clutch has been replaced by mercedes dealer less than a year ago due to a noisy sc clutch bearing. This might sound dumb, but how do you differentiate a belt slip from sc clutch slip? Also, could the torque converter be slipping as well? On second note, my transmission, radiator, torque converter, tcu, idler pulley, sc clutch have been replaced under warranty.
