Oil filter seal leakage, onto the belt.
Obviously I plan on replacing the filter and the o-ring as soon as I get a chance. Will also wipe down the belt and pulleys. Other than the potential for some slip has anyone had an experience with this and is there much danger?
You say you used an aftermarket filter; did the filter come with new O-rings? Did you replace them all?
If you did not replace the O-rings and the top one failed due to deterioration (the one sealing the cap) I would be afraid one of the smaller (and more important) ones might fail for the same reason and damage the motor. If you did replace the O-rings, the top one may not have been seated properly in it's land.
The oil leaked directly on the belt and just slipped right off. Luckily this happened right in my drive way, other wise I would have been stuck. You definitely need to get the problem taken care of because your belt is bound to slip, just like mine did.
