SL55 intake
Old Jan 15, 2010 | 09:00 PM
320 dreamer's Avatar
2003 porsche 996 turbo
thats the c3 fitler for the c32. you remove the backing plate off of the intake and install the filter. i built one bigger than that for under 25$
Old Jan 16, 2010 | 01:15 PM
SilverBulletAMG's Avatar
C32 AMG
Originally Posted by FrankW
my normal logic tells me that the whatever air volume that's pushed through the airbox when the car gets going will end up being pushed out of the opening with the C3 setup. maybe on a hotter day it would let hot air escape lol
My normal logic tells me air (like water) would travel the path of least resistance....the open TB and SC sucking it all in. Does the C3 style draw in some under hood air? Yeah. Enough to make a difference? None that has been proven.
Bang for the buck, you cannot beat a C3 intake (or cheap DIY version) with larger intake tubes up front. I would love to be proven wrong and see something that shows the same (or higher) gains, has as good of a sound, and has as good throttle response for less $$.
Old Jan 16, 2010 | 02:01 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
then you do not want to know how much my entire airbox with BMC was.
Old Jan 16, 2010 | 02:29 PM
your entire engine bay is one of the best sealed units around. from the small grill opening crowded by intalkes and radiator to the sealed rear lip of the hood to the belly pan used for areodynamics the only air going in is random turbulent hot air in the engine bay.
the dyno tests posted by the old c3 site were for pulley AND filter with no mods to the tubes.
i run full 3" tubes into gutted airboxes with k&n fiters and needswings devil horns. when i put the c3 style filter on i lost power , removed them and power was recovered. the smooth flow of cold air wins period
Old Jan 16, 2010 | 03:44 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
agreed in terms of bang for your buck its probably the best deal. Granted the sl55 intake will yield more power but its also $300.
Old Jan 20, 2010 | 10:00 AM
c32kompressor's Avatar
CLK55 AMG
were can i find the whole sl55 setup, splitter and all?
Old Jan 20, 2010 | 11:32 AM
  #32
BigBodyBenzC240's Avatar
...a panty dropper...
Parts.com or get lucky in the classifieds
