small problem, but a pain...
Old Mar 18, 2003 | 12:19 AM
c32yep's Avatar
It's a nit, but a pain. My son unscrewed the door lock in the rear seat and now it will no longer engage with the mechanism. The door is permantently locked from the outside.
Any ideas? Do I need to go to the dealer or is there an easy way to fix this?
Thanks.
Old Mar 18, 2003 | 12:34 AM
Harris's Avatar
You can take off your door panel and get the door pin stick back up again. Not too hard to do it. Do you know how to take off the panel?
Old Mar 18, 2003 | 08:56 AM
c32yep's Avatar
no -- any instructions available for taking off the panel?
Old Mar 18, 2003 | 01:25 PM
Harris's Avatar
I hope my memory serves right, there are 3 areas where you have to unscrew:
1) SRS badge, there should be a screw behind it
2) The plastic handle, there should be a screw behind it
3) The door lock latch, there're a couple of screws there
Then tug the whole panel UPWARD (OR you might be able to pull the panel out a bit and get the door pin to fit in place without tugging the whole thing out).
I hope I've saved you an hour of labor at the MB dealership!! Good luck!!
Old Mar 18, 2003 | 04:09 PM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
That happened with my crappy old set of Brabus Door pins, Try hitting lock,getting a needle nose and fish for the top of the door pin screw then yank it out. If not take the door pannel off.
Harris is coorect on the screws
