How do you SLOW down the trunk lid opening?
Old Mar 18, 2003 | 05:23 PM
Bux's Avatar
Bux
G
Question How do you SLOW down the trunk lid opening?
there was a DIY on this on the c32 boards.....anyone have it bookmarked? i've tried search
Old Mar 18, 2003 | 06:06 PM
LorinserCClass's Avatar
The True OG Modded out W203
put a nice new decklid spoiler.
Old Mar 18, 2003 | 11:15 PM
AMGDood's Avatar
C32 AMG
actually i want to know too...ive had a few friends accidentally get hit becuase they werent expecting it to come up so fast.
Old Mar 18, 2003 | 11:42 PM
Larry Sonsini
Guest
Posts: n/a
don't know about the link that you speak of, but you could always dynamat the trunk.
Old Mar 19, 2003 | 02:07 AM
rrf's Avatar
rrf
Here is the message for trunk springs
The original message was for opening "faster" so
just reverse to have trunk lid "go up slower".....
____________
After banging my head on the trunk lid a few times when getting stuff out, I noticed that the lid wasn't going ALL the way up. The lid usually seemed to stop at a detent position, approx. 3/4 open. It could be pushed further open by hand.
Simple fix, open trunk, remove the 4in by 8 inch Rear Light access panels coverings inside the trunk, and move the spring(s) to the next rearward position.
Mine were in the #2 hole and I moved them to the #3 hole (most rearward).
All I needed was a vicegrip to grab the spring and a flashlight. Literally a 2-minute job.
One note, since the trunk will open all the way, be sure you will have overhead clearance.
If you need even more opening force, there supposedly are adjustment holes at the other end of the spring. Those adjustments seem to be harder to access though.
Old Mar 19, 2003 | 12:23 PM
C32Andy's Avatar
2016 C300
the dealer should be able to adjust it for u
Old Mar 19, 2003 | 05:53 PM
my401's Avatar
c32
deck lid
this is easy ,,, move spring location to closer hole. (spring located behind carpet panels on side where trunk arms go.)
However I had problems sinces moving springs that the lid doesnt open all the way and I've hit my head several times I will probley move back springs.
