C55 Intake
Old 09-01-2010 | 05:27 PM
FrankW's Avatar
MBworld Guru
white and whiter
Originally Posted by Newzchspy
Funny thing is that Kleemann DOES NOT recommend the use of KNs or any other after market filters other than stock for their SC applications. Don't know why BUT they don't.
because they want to be on the safe side to prevent people over oiling the filter and somehow allow oil into the s/c and cause some damage.
anyway, I just changed out the filters on my 204. I have drove it yet, but the stock paper filter is huge inside the 272 airbox. the front inlet is basically blocked 60-70% by the side slab of the filter. the K&N is much thinner in comparison which it doesn't block the inlet at all.
Old 09-01-2010 | 05:36 PM
Berezeknees's Avatar
06 C55
Well I guess Kleemann has their reasons for their SC applications. I was also thinking that this rear mounted TB lends itself to some sort of hood mod with a flat panel filter integrated into the rear grill area. I think that option has been talked about here before. I would not want to go the chevy rear scoop hood route tho-
Old 09-01-2010 | 07:48 PM
buffyclk500's Avatar
clk500
Originally Posted by C55Newb121
I was thinking about running a 3" intake tube down to the area by the passenger side fog light and putting the air filter there. I think I could do it with minimal bends. I think something like that would make it easier for the engine to suck the air in. It might not look as good as the stock setup, but the stock air box doesn't seem like it would work too well for maximizing air flow.
I am going to try and work something up in a couple weeks. I will start a thread do discuss my plans, reasoning, and post pictures. Stay tuned (pun intended)!
somthing like this
Old 09-01-2010 | 07:49 PM
clk500
i also have a heatsheild but no pic
this works great
Old 09-02-2010 | 04:43 PM
06 C55
Originally Posted by buffyclk500
somthing like this
Yes that's exactly what I would want to to do. Do you have part no.'s and website for all that stuff? I'm diggin the red valve covers BTW
Old 09-02-2010 | 05:28 PM
clk500
it is on a clk500
i no on c32 there is no room for this setup
but if there is room on your c55 i will sell u my setup for cheap
Old 09-02-2010 | 06:11 PM
  #32
06 C55
it is on a clk500
Whats Cheap?
Old 09-02-2010 | 07:20 PM
  #33
clk500
pm sent
Old 09-03-2010 | 07:52 AM
  #34
C55Newb121's Avatar
2006 C55
Could you provide us some feedback on that setup? That is exactly what I was thinking about doing.
I would like to go with something chromed or polished though. How much were you looking to get for that setup? Was it easy to install?
Old 09-03-2010 | 02:48 PM
  #35
clk500
it is not hard 2 put in the hardest part was u need 2 take the tire off 2 put the filter in
and yes it can b any color
mine is black on the top and chromed on the bottom for heat
Old 09-03-2010 | 03:05 PM
  #36
C55Newb121's Avatar
2006 C55
What kind of feedback do you have for us on performance? Fuel economy?
Old 09-03-2010 | 03:11 PM
  #37
betrezra's Avatar
C63 507 AMG DA Car #19
It looks like you could move your battery to the trunk, and put the air filter where the battery used to be. Just a thought...... looks like nice access to cool air where the battery is located.
Old 09-03-2010 | 03:15 PM
  #38
betrezra's Avatar
I'm thinking Kleeman does not rec any aftermarket air filter with the blower install to min the chances of bad MAS signal and detonation and engine damage if filter is over-oiled.
You can get away with poor MAS readings N/A....... but with forced induction a BAD MAS reading... IE - lean with our high comp 11:1 will lead to engine failure.... coupled with the fact that our pistons are cast ...... not forged....... you're playing with fire.
I ran some aftermarket filters out of the box on my N/A CLK and the MAS crapped out in 2000 miles.......... when it crapped out the car bucked bad, and would not idle...... the scary part was that the issue did not crop up at all until I was WOT @ 5K rpm under full load and the engine bucked really bad......... limped home, threw a MAS code..... new MAS and all is good.
Old 09-03-2010 | 04:28 PM
  #39
clk500
my best mpg was 28mpg but i have other mods
for power i dyno 271whp and 300wtq with intake and exhaust
and 1/4 my best stock was 14.1
intake exhaust 13.5
header, exhaust and intake 13.2
all on street tires
Old 09-03-2010 | 04:30 PM
  #40
clk500
the only thing is the ac pulls air from there and mayb water
but if u move the battery that will help with weight also they have some that r around 14lb stock is around 45lb
Old 09-03-2010 | 04:34 PM
  #41
clk500
what messes up the mas is the oil in the filter
i had renntech airbox with k and n filters and my mas went bad after like 20000 miles
this setup has a dry filter
Old 09-03-2010 | 04:37 PM
  #42
clk500
this is a old video but u can see how it sounds
http://www.youtube.com/watch?v=8r58TPGMkIs
Old 09-03-2010 | 07:14 PM
  #43
RLx02's Avatar
C55
great time for a 500!
Old 09-03-2010 | 07:41 PM
  #44
clk500
Ya with dr tires and lighter rims I might do a 13.0
Old 09-04-2010 | 02:25 AM
  #45
RLx02's Avatar
C55
Yeah I ran a 13.1@107.7 with heavy 19" wheels and nothing but a tune. Since then I put headers, new tune and have 18" wheels and DR's on the back but I didn't make it to the strip before the season was over
13.0-13.2 is a total sleeper time for a non AMG...I drove my friend's stock clk500 and definitely did not feel anywhere near the 13 second range...thats awesome.
Quick Reply: C55 Intake
