Help me figure out this terrible engine whine - C55
Old Feb 20, 2010 | 11:51 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Originally Posted by FrankW
sounds like one of the idler bearings have gone bad.
this is how mine sounded when the supercharger bearing went bad. http://www.youtube.com/watch?v=LAcmJRZrpBo
I also had one of the idler bearing went bad and blew apart. no sound clip tho, but pretty much the same noise. it comes and goes because when you stop and let off the belt tension decrease and engine noise dies down which makes the grind more apparent.
OT for this thread, but Frank, if you're referring to how the S/C pulley bearing grind/rattle noises come and go, by my understanding it's because that bearing is only working when not under load. So as soon as the S/C engages, the noise goes away b/c the bearing isn't spinning. Mine's pretty bad right now - need to get to the dealership svc. dept. for a replacement.
Viper - sorry for the OT, good luck with your situation.
Old Feb 24, 2010 | 08:27 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Any tips on releasing the tensioner? Are you just supposed to rotate it counterclockwise via the center bolt? The center bolt seems to be a tamperproof torx, T50? Any confirmation?
Old Feb 24, 2010 | 08:32 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
no, I was talking about the tensioner pulley grinding noise.
the vid of s/c bearing noise is just showing how might a bad bearing sounds like. they all sound one way or another the same.
Old Feb 27, 2010 | 04:06 PM
Viper98912's Avatar
In case anyone was curious, the new pulley bearing is tight and doesn't make a peep.
http://s372.photobucket.com/albums/o...dlerPulley.flv
Old Oct 8, 2010 | 06:21 AM
Gorgatz_3's Avatar
IMHO....A/C compressor
pulley
Old Oct 9, 2010 | 12:50 AM
Viper98912's Avatar
You brought back an 8 month old thread that I already posted my resolution to?
Old Oct 9, 2010 | 02:49 PM
  #32
Quicktwinturbo's Avatar
CLS, SLK, ETC
ROFL~
Old Oct 11, 2010 | 05:45 PM
  #33
Newzchspy's Avatar
PLAID
Trying to get his post count up!!
Old Oct 12, 2010 | 12:01 AM
  #34
mikekuriger's Avatar
2010 C63
mine has had a LOUD whine since I got it. I changed the PS fluid and that didn't help. After 120,000 miles I'm guessing it's not going to get any worse.
