HOw to Open the trunk if your battery is dead?
Come on people, be smarter then the car.
http://www.youtube.com/watch?v=zGvj6ajdXdA
Of course on a W208 CLK, there's a plan B.
The attached picture is of a W208 CLK. In the picture there is a red arrow. The arrow points to a plastic cover. On a W208 CLK, the owner removes that cover, and applies 12V positive to the wire under the cover. They apply a negative ground anywhere they can. At that point, the owner can use either their electronic key or the switch in the car to open the trunk. So . . . . . . . does the W203 have a cover in about the same spot? If so, will a W203 owner with a volt meter confirm that the wire under the cover sees 12V positive when the car is turned off?
Lastly, DO NOT EVER use that wire to jump the car.
