Mobil 1 ESP Formula M 5W-40
Old Feb 12, 2012 | 04:25 PM
  #51
GTibunny8v's Avatar
2005 C55
There are 2 5w40 oils used by Mercedes. 5w40 Formula M which is 229.5 and 5w40 ESP which is 229.51. 5w40 Formula M is approved for the AMG M113.
Old Feb 12, 2012 | 04:30 PM
  #52
nardeezy@yahoo.'s Avatar
E63 AMG
Mobil 1 only makes the
5w-40 in one oil "ESP Formula M"?
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_ESP_Formula_M_5W-40.aspx
Old Feb 12, 2012 | 06:28 PM
  #53
GTibunny8v's Avatar
2005 C55
Just cause its not listed on that website doesn't mean its not produced. I use it everyday at work. Here is the data sheet from Mobil.
http://www.mobil.com/USA-English/Lub...a_M_5W-40.aspx
Old Feb 12, 2012 | 07:17 PM
  #54
E63 AMG
Great! U have a link for how to puchase? I can only find the 5-w40 in the "ESP Formula M"?
Old Feb 12, 2012 | 07:44 PM
  #55
NCE500's Avatar
2007 E63, 2006 C55
Mobil 1 5W-40
My dealer put the new ESP 5W-40 in my E63 last Summer, when it was HOT outside. I noticed from day 2 after that service there was a little audible lifter noise at initial startup, lasted about 30 - 60 seconds and then all was fine. Engine ran super once warmed up, and the oil lasted a long time without getting discolored much. The 5W-40 is a quality oil.
However, I did my customary 6 month oil change at home last month, used Mobil 1 0W-40, and cold start lifter noise is completely gone. Engine revs freer when cold, but once warm no perceptible difference in performance.
I say my 156 engine is happier with the 0W-40, while the cold start lifter tap was likely harmless, it was not there before the 5W-40, and is not there after it either.
I'm sticking with 0W-40 going forward. Have also always used the 0W-40 in my C55 and V12, never had any lubrication issues with either.
Old Feb 12, 2012 | 07:54 PM
  #56
E63 AMG
Great observation and thanks for the feedback!
Old Feb 13, 2012 | 12:27 AM
  #57
grane's Avatar
GLK350, SL63 AMG
Using 0-40 Mobil, many people have reported similar positive experiences with other engines. Nice job.
Old Feb 13, 2012 | 12:29 AM
  #58
grane's Avatar
GLK350, SL63 AMG
Does your shop get it in bulk containers?
Old Feb 13, 2012 | 01:49 AM
  #59
E63 AMG
I'm assuming the place he works may get it in 55gal drums because I can't find a 5W-40 Mobil 1 Formula M w/o the ESP acronym associated with it.
Old Feb 14, 2012 | 09:58 PM
  #60
GTibunny8v's Avatar
2005 C55
I work at a dealer. We get it in our bulk tank. We also sell qts of 5w40 Formula M and ESP. ESP is only recommended for use in diesel vehicles with a diesel particulate filter (DPF).
Old Feb 14, 2012 | 10:20 PM
  #61
E63 AMG
Do you work at an authorized Mercedes dealer?
Old Feb 14, 2012 | 10:30 PM
  #62
E63 AMG
Do you know how a normal consumer can obtain the Mobil 1 5W40 Formula M (without ESP)?
Old Feb 17, 2012 | 02:03 PM
  #63
kent426's Avatar
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
I by the stuff every oil change at Oreilli's auto parts, it is a diesel motor oil so they sell it in 1 gallon jugs, we need 2 gallons anyway.
This oil should eliminate sludge buildup.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
