I need a sSupercharger Pulley
I took the s/c pulley off my C32 this afternoon. After replacing the bearing, which I thought would fix the noise, I realized the noise was coming from the slop in the plate at the rear of the pulley. Unless this can be repaired, I guess I need a new s/c pulley. Please post any shops that offer a replacement part. I am aware that Mercedes charges over $1K for this part. I believe it is the Flange repair kit - A 112 090 00 44. Please help!
2002 C32 1987 190E 2.3 334K miles and going
I didn't know you could replace the flange (clutch?) plate on our S/C. The unit I got from Code 3 had one of the rivets that connected the plates loose making some tinging noise. On top off that, the spinning flange was wobbling slightly hitting the back plate. I had to add extra shims to move it away the back plate.
It's okay now and I don't hear any noise from the S/C.
Thanks. I don't think the extra shims will help in my situation. The plate is not touching the clutch. There is enough clearance. The problem seems to be the looseness in the plate itself. I suppose because of the rivets. Do you know if HP Autowerks our anyone else offers a replacement s/c pulley?
