Alignment - C32
Old Feb 5, 2002 | 08:44 PM
tsmb32's Avatar
2002 C32 AMG
Unhappy Alignment - C32
Hello. I'm new to this board but I have found it both helpful and entertaining. I'm a proud owner of a C32 but I've been experiencing an alignment problem. The car pulls to the right. The mechanics at the dealership say that the computer states that the alignment is correct but then they notice a slight pull themselves when they test drive it. Has anyone else with a C32 experienced this problem? I noticed on the E-class board that several people had a similar problem with the E-55.
Thanks.
Old Feb 6, 2002 | 02:33 AM
Vadim @ evosport's Avatar
C32 AMG
Mine C32 had the same problem. You need to have caster redone with new bolt kit. See my post on C32life.com. I do not have the part numbers in front of me now.
Old Feb 6, 2002 | 02:38 AM
awiner's Avatar
2003 CL55 AMG
The part # for the alignment bolts are:
000-330-00-18
Old Feb 6, 2002 | 09:31 AM
revstriker's Avatar
K Car
Does anyone know if this has been a problem on any other C Class cars?
Old Feb 6, 2002 | 01:54 PM
Andy's Avatar
C240
I've got the same on my c240, will ask dealer fix it this week.
Old Feb 6, 2002 | 07:57 PM
tsmb32's Avatar
2002 C32 AMG
Thanks for the advice on the caster bolts; unfortunately, that is what the dealer did to repair the right pull, but it hasn't worked. Car is still pulling right, although computer printout of alignment says it is perfectly aligned and should go straight. Tire pressure was okay, too.
Dealer is going to have tires removed and swapped left to right to try to find a possible tire problem. Doesn't sound promising to me. Very frustrating for a C32 with less than 800 miles!!
