Nitrous Q's
Subscribe
Oct 11, 2010 | 07:54 AM
For all of you that has ran the zex 55-75 shot, What shot have you used and what results good and bad? Also what wire do you tap into for the WOT reading on the tps? From what I gathered I think its the yellow one. How hard was it to set to box for WOT? I know we are fly by wire and didnt know if you can open and close the throttle body without it running.
Kevin
Reply 0
Oct 11, 2010 | 12:12 PM
Quote: For all of you that has ran the zex 55-75 shot, What shot have you used and what results good and bad? Also what wire do you tap into for the WOT reading on the tps? From what I gathered I think its the yellow one. How hard was it to set to box for WOT? I know we are fly by wire and didnt know if you can open and close the throttle body without it running.
Kevin
To set the box is very easy, read step by step the instruction coming with the kit, then verify it by turning the engine on at idle press the pedal down and you can hear the box turning on and off (with bottle close).
Reply 0
Subscribe
Currently Active Users (1)
