TONS of left over parts. Is there any value in used engine parts?
Old Oct 12, 2010 | 04:49 PM
chamm's Avatar
2002 c32 amg
After the long process of rebuilding my engine, I have lots of left over parts. I was wondering if there is any value in some of these parts. I figure I can just recycle the block and heads as scrap aluminum, but it seems like a waste being they are AMG parts, and would like for them to be put to good use.
I have:
1 stripped down block in good condition
1 complete short block with pistions and crank
1 pair of heads complete with valves, camshafts and rocker arms
1 pair of stripped down heads, that have some damage
1 set of valve covers
1 damaged crankshaft
4 pistons with connecting rods
1 pair of stock cam shafts
1 pair of rocker arms
10 coil packs
2 sets of fuel injectors
2 pairs of the intake plenums
1 complete supercharger
1 back half of the supercharger
2 intercoolers
1 throttle body
1 pair of stock slk32 headers
Slk32 Oil Pan
2 waterpumps
1 alternator
1 ac compressor
1 power steering pump
1 starter
1 stock intercooler pump
1 stock heat exchanger
1 stock ECU
1 Transmission, with a broken front half of the case, where the cooler line attaches
1 complete engine wiring harness
Old Oct 12, 2010 | 05:29 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Ebay them if you have the time.
If I had a c32, I'd pick up those heads and have them ported/polished gasket matched.
Old Oct 12, 2010 | 09:05 PM
loudandheard's Avatar
C32/C55 AMG
I can't believe you have so many left over parts. You should build a 3.7l m112 engine with the left over parts. I think you could make an engine with over 400hp.
Old Oct 12, 2010 | 09:46 PM
OverDrive's Avatar
Volvo
How many miles are on the parts?
Old Oct 13, 2010 | 03:45 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
you can probably sell them on the w203 for someone how wants to try to supercharger the c320.
