c32 alloy size
AQUIRED A C63 AMG PPP
c32 alloy size
hi ive been offerd 19 inch alloys with tyres quite cheap and my c32 alloys are quite worn but the only problem is the 19 are 19x8 all round does any one think they would look odd and skinney at the back or would they be ok
I think it'd look odd. The rear wheel well is larger than the front so your tires in the rear would be sitting pretty far in there. If you got a spacer to push it out flush with the wheel well it wouldnt look too bad, but then you still have bike tires in the rear haha, plus you wont get any traction!!
U can run staggered tires, but still check the offsets as you may have problems clearing the brakes.
Personally, I run 255's on my stock rims, but would like to run wider in the rear still. I think u can still run 245's on the 8" rims, but 225's on the front will have a harsher ride as they'll be more stretched out.
Unless you're totally positive they will work well on the car, I wouldn't do it.
2002 Silver c32
carefull
Make sure you test fit. Lots of rims don't clear the front calipers. You can put wheel spacers on the front if you want.
