No horn
Old Dec 10, 2010 | 04:16 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
No horn
My horn doesnt work. Is there a common issue with these plastic horns not lasting too long? Relays clicking, wires at horns with multimeter are getting enough power when pressed, and scraped horn connections so no corrosion. its about 6 degrees out right now so going to test a 190E horn on the connections tomorrow, just wanted to know if this happens on 203s
Old Dec 11, 2010 | 11:27 PM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
When I bought mine someone had removed the fuse apparently. You're getting voltage so that's not the case...
