C32/Crossfire engine swap
2002 C32 amg
The answer to this question wasn't clear in other forums. If I took the engine out of a SRT-6 and put it in my 2002 C-32 AMG, how would I deal with the difference in ECU's? Am I able to just plug the the crossfire ECU into the C32 and have it reprogrammed? I would assume this would be an easy swap, but I'm not a mechanic.
If I ever did this, I would buy a Kleeman cam....
CLS, SLK, ETC
May I ask why you plan on doing that? I think it's possible but wouldn't it be less hassle to just go with the C32 engine? In the end, they are the same engine or similar correct?
CLS, SLK, ETC
But if you are willing to go through with all the hassle, good luck with it~!
2002 c32 AMG 2012 c250 Coupe
2002 C32 amg
Well, I just bought a brand new SR-T engine. 2005; 0 miles.
If someone wants to buy it off me: 8,000 obo.
If my engine blows up, I'll find a way to swap it out. What would the hassle be that you guys speak of? This would solve the tranny jerk problem and put peak hp in my 9 year old car......
What I really want to do though is find an SLK32 and swap it out with that and have some fun with it.
2003 porsche 996 turbo
not sure what issue you are thinking of. the srt-6 engine is identical to your c32 engine. the ecu recognizes the car not the engine. plug and play
the slk32 also has the same engine so your not gaining anything there.
**EDIT** rcompart is his username
2005 C55 AMG
I guess I don't understand why you would want an engine with 0 miles, and the rest of the cart with 105k miles. I suppose you might not have engine troubles, but everything else is going to have to be replaced @ some point too... Plus you'll never be able to sell the car.
2002 C32 amg
But my goal is to make money on this, either flipping the engine, or buying a c32/slk32, putting in the new engine and selling it. margins are tight though.
2005 C55 AMG
I've dumped 20,000 in new parts for the car, if me engine failed it would almost be a good thing, I'd have a brand new engine to go with the parts.
So who do you think is going to buy the car with 105k miles on the chassis and a new motor? Not even a new C32 motor... sure its the same, but different part number, doesn't match VIN, etc. Anyone who knows anything about these cars enough to be an enthusiast would steer away. Not to mention potential title issues. And FYI there isn't going to BE a profit margin unless you manage to sell a 105k mile C32 for over $20,000.
Why not buy a kit car and put the motor in that? Hell, even an MX-5?
you dont have to trick your car to do anything. ITS THE SAME ENGINE. the ecu recognizes the 3.2 s/c engine not the specific vin of the engine. its plug and play. now iif your droppping it into a slk320 chassis then you need to reprogram. as your car already has the same engine its just going to see the same thiong it sees now
03 g35 coupe...........02 c32 Sold
the engine and tranny itself is mechanical and is operated by the ecu and tcu. If you reuse your old ecu and tcu, then you don't need to reprogram anything. Its direct plug and play.
