New Pictures - CLK63 Brakes!
Whats the difference between the CLK63 brakes and the 030 SLK55/CLK55 brake upgrade package?
Can you post a closer picture of your rear brake setup if that was changed also.
Thanks.
Thanks.
Here are the part numbers I have for the CLK63 setup:
CLK 63 AMG (Front)
003-420-67-83 (caliper)
003-420-68-83 (caliper)
209-421-01-12 (rotors x 2)
005-420-39-20 (Brake Pads)
SLK 55 AMG 030 Performance Pack (Rear)
003-420-29-83 (caliper)
003-420-30-83 (caliper)
171-423-02-12 (Rotors x 2)
005-420-41-20 (pads)
I don't understand why these would be different from C63 brakes...not doubting they are, it just doesn't make sense.
The C63 brakes are different because the suspension is all different (also why I had to use spacers to use the wheels). The CLK63 brakes work because the W209 suspension is exactly the same as the W203 (except for the CLK63 Black Series, which is different).
On the C63, the entire caliper, rotor size, offset, bolt size, piston size, etc, is different. Taking the time to compare a simple picture or two would have shown you this.
