Guys You need to start using Meth InJection! This has become an industry staple
Will do. I’ve installed and tuned with the SnowPerformance kits quite a bit, and they yield great results. Like zero timing pull at insane levels of boost in the super high temps of summer, on road trips with LONG full throttle pulls (like multiple back to back top speed runs and ZERO timing pull at all)
it also saved a motor of mine that lost the vac line to the wastegate under full throttle and the system sprayed its little heart out and saved the motor from a super lean condition. The injectors couldn’t keep up, and the SP meth kit kept things in check. I don’t suggest using it for that reason, nor did I intend to, but I was glad it was there.
When I do it you guys will know.
