Strange Power Loss
I'm a bit scared here that I might be looking at replacing the supercharger AND the transmission, that would really kill my economy.
Mechanic didn't say that though, but I'm still fearing the worst. Would be typical of my luck.
I have the same problem with the power loss on the freeway ill be driving and go to pass and there will be no power????
than ill try on a diffrent day and it will work????
ill check all the above soulotions and hopfully it works but any one have a good place to start. i just dont want to but all theses parts if i dont have too ....yet
and thanks for all the help!!!!!
Kevin B
There's a common transmission leak from the electrical connector. This would not cause any severe performance issues, but your tranny may not shift as smooth and feel a bit different.
I paid $450 to have the idler tensioner? and belts replaced. They charged me for 3 hours of labor, but the car was ready after 2. Also when I tell them to check the intercooler pump they always tend to change the subject. I think I'm getting robbed here.
An investment in a good ratchet set and you could save your self a lot of money. There are lots of great diy threads on this forum.
It removed the noise from the belts, but it's still a ticking noise coming from the top left of the engine. I took a quick video from my phone.
http://www.youtube.com/watch?v=eCITygyj63A
You can hear the belts are running quietly, but there's still some weird noise in the engine, any idea what it could be? My old car had the same thing, someone told me it was lifter tick. Could it be the same here?
Also could be perfectly normal and I'm just paranoid. It's just that every strange sound I hear from this car makes me scared
My car is an 03 and I have pretty much gone through all the annoying problems listed in this forum. I have had to replace my intercooler pump, the smog air pump, idler pullies, control arms and bushings, radiator.
Over the years, my car still felt powerful, but has somewhat lost that thrust of acceleration it used to have...but I just thought it was due to car getting old. I top off my window washer tank/intercooler (Evosport Evolution 2 package) every now and then since I also do use my window washer. (For those who are confused with what I just wrote...Evosport kit isolates the intercooler circuit from the engine coolant by utilizing the window washer tank which provides 6.2 liter of window washer water through the intercooler). Never did realize I was loosing to the intercooler...
One day, the dreaded sudden power loss resurfaced, and I just though that the intercooler pump went out again. But then this time it was something different...the car misfires, stalls, and everytime it restarts, it puts out a cloud of smoke (water vapor) from the exhaust. The car is in constant "limp" mode. I had a shop pull the code and was just told that the spark plugs and wires need to be replaced. Got those done but the problem persisted. The car would run fine for few minutes first thing in the morning, then would be very sluggish afterwards. Stumped, I decided to top off my intercooler water reservoir (window washer tank) and realized it was running almost dry. I topped it off and run the car, it started running very rough and water vapor coming out of the exhaust...thats when I realized that the intercooler was leaking water and "water injecting" the hell out of the engine. Took out the old intercooler and there was all kinds of buildup within the core. Apparently it started out with a slow leak which did not affect the car much at first, but the water leak steadily collected microns of dust particle over the last couple of years and turned it into a clay like substance whick also blocked the flow of air through the core. This caused premature hot spots within the core which eventually widened the crack and failed.
The intercooler had been replaced, and the brutal "thrust" is back...all 432hp 427 ft-lbs of torque. Very happy except one thing...flooring it from a stand still causes the torque limiter to kick in and shuts off the gas pedal...have to shut the car and restart in order to get the gas pedal back. It only happens when I floor the car from a stand still.
I think either case, it would be advisable to peek into your intercooler cores every now and then (yes I know its a pain), especially those of you who use aftermarket high flow filters...if you car is sluggish, it just might be gunk accumulation in the intercooler halting the air flow...
Regardless of whether you are losing power or not, I still recommend all of you to peek into your intercooler core especially if you are using oiled high flow filters such as K&N or Green. Compared to the oem paper filters, these filter do let more particle into the engine (compared to paper) and for me 9 years worth of accumulation occurred in the intercooler. I will try to post a photo of what the core looks like. The inlet is filthy, but the outlet was relatively clean. I believe just cleaning the intercooler once every blue moon will prevent headaches and keep the air flowing through the core at optimum.
