Command Screen - Can it be customized on start up?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hello,
I have an '06 C55 with a Command screen (navigation). Does anyone know if the command screen can be customized such that the screen will open (default) to the map instead of the blue audio screen on startup?
My Lexus will display the map on start up. I'd like for my C55 to default to the map image if that is possible?
Does anyone know if this can be changed (either by me or the dealer)?
Thanks,
Thanks,
On mine I think it comes up on the last thing you were at. If you leave the map on when you turn off the car, the nav input screen will come up (the first time in the drive cycle you press map it defaults to the nav first). I don't think there's a way around it
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Volvo
Ok i looked at it, and found where the image is stored...... Its in a dll/system file. I used the service disk to find it. Im not sure how to change it (I'm not a software engineer, Only hardware
) but it seems like if theres a way to import the same size image into it, and recompile it somehow... I think it would work.... again im guessing here....
I wasn't surprised at the answer.
