C55 engine whine
2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
The whining noise is NOT the air pump! The noise that this post is trying to diagnose is distinct and so far considered normal and heard in several models / engine variations.
I would be very interested to know if someone has replaced their oil pump and that solved the problem.
I have the same whine discussed above in my C55. It is only there on cold starts. It is frustrating as it prevents you from listening to what a proper V8 should really sound like in a cold morning! My mechanic first thought it was the pullies, so I changed them. But the problem persists. Now he suggests it is the air pump. To prove his theory, he disconnected the pump and the noise was gone. His solution is to disconnect the wire of the air pump and have the peace of mind. He argued that in hot climate having this pump is not really essential. Is this true? Anybody with any better knowledge or tried it?
#33
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
#35
C32/C55 AMG
I had the dealer replace a pulley, but I did not solve the engine whine. Must be a c55 thing. The c32 is much quieter on startup, the c55 engine whine reminds me of the sound the c32 makes when the supercharger pulley bearing is going bad, just more high pitched.
#38
'09 SL65 AMG
#39
I have a whine that gets louder when the engine gets higher RPMs. Specially in 1st, 2nd and 3rd. Is it going to stop if I perform a transmission oil change? (maybe that is the reason, I'm reaching the 50k mile mark).
#40
BTW, I didn't have that sound a week ago... Any ideas?
#43
I have the same whine you better hear it at cold start up because of additional rpm as your engine heat up just put your leg on acceleratore up to 1200-1500 rpm you hear same whine. It is steering pump, i will try to proove it by taking out the Engine belt then will listen. Other knocking sound i hear is under drive wheel not lifter tiping other one much muffled.
#45
whine sound in the engien
I have a 2005 mercedes benz c55 amg for 2 years and the whine noise has be lauter by the time i thinck this sound cant be normal because is ogly peple tell me i have the power steerin pump bad but thats nat true because whith the serpentine belt remove do the same, we need to now wat the problem is.
#48
I bought one of these without ever driving or even seeing one in person. So the first time I heard it start I thought something was seriously wrong. I did some quick research, watched some youtube vids and I guess its normal. Mine is plenty loud though so I'm keeping an eye on it.
#49
2006 C55
I've listened to a bunch of c55 videos and they all seem to whine, mine did it too. Mine made a power steering whine since I had it and I recently flushed the PS fluid and it wasn't the correct stuff, added the correct stuff and it sounds 10x better. Couldn't believe the difference. I know it's an old thread but may be a cheap way to start.
