C55 engine whine
Old Jan 6, 2016 | 07:19 AM
  #51
Khan 55's Avatar
2004 CLK55 AMG W209
After I did a tranny service I heard it. I was like, "oh no pls tell me everything is okay." So I googled it and people here on the forum and elsewhere mention its normal. The oil pump sounds like that cause of the design. Something to do with its pumping galleys or because it has two pick ups or something. They mention its the sound of the engine's heart being the oil pump.
Off topic but anyone while at it check if their harmonic balancer/crankshaft pulley runs like its vibrating or looks normal or someone can post a video of it in motion for me please? Think I need to order a tool later to remove it and see if the wood ruff key if any still looks fine and so is the key way slot on the pulley or is mine bad.
Old Jan 6, 2016 | 08:14 PM
  #52
loudandheard's Avatar
C32/C55 AMG
So I figured out where my whine was coming from, it turned out to be the water pump making noise. By spinning the pulley without the belt you can hear a slight wine. Once I replaced it, the engine was much quieter.
Another place it could be coming from is air injector pump at the front of the engine.
Old Jan 7, 2016 | 12:16 AM
  #53
joc's Avatar
joc
2015 E350 4 matis, 2003- 911 porsche
Guys There seems to be a lot of thoughts here,mine was the air pump it whined like an old goat when it was cold, so go through it like an engineer!
1. Air pumps have been an issue as per M Humaid said check air pump first by removing air lines and hoses and making sure it is not that.
2. Take belt of and check tensioner and then water pump, how do they feel rough or smooth.
Hopefully that gives you some ideas
Old Jun 7, 2017 | 01:35 PM
  #54
PJmak's Avatar
The c55 I got has a constant whine which makes the car sound like its supercharged.
Previous owner said its the steering pump filter thats inside the fluid container.
I plan to run the engine with no belt on to rule that and the idler pulley out. Its a bit annoying to be honest and Id want it fixed.
Old Jun 7, 2017 | 06:19 PM
  #55
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I'd be very interested in what you find out.
Old Aug 13, 2017 | 03:20 AM
  #56
duke749's Avatar
C55 AMG
ilder pulley
hi i had the same on my C55 change the idler pulley and is all good
Old Aug 13, 2017 | 03:27 AM
  #57
duke749's Avatar
C55 AMG
whine
Originally Posted by mikekuriger
I've heard it since new, just wondering what it is. I know what it isn't (now).
It's not the alternator, water pump, ac, power steering, or idler pullies.
My car makes the same noise with no serpentine belt. Maybe the oil pump?
my heater fan sometimes has a slight whine
cold start the air pump whines
Old Aug 13, 2017 | 03:29 PM
  #58
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Cold starts always have the air pump whining. When the pump starts going out, the whining ramps up. Was told it's for cold-start emissions, which makes sense, and it would throw a code but not affect drivability when it did finally die. Mine's been whining a bit extra for over 2 years now. Maybe a full minute instead of the usual 30 seconds or so.
Old Jan 28, 2018 | 03:25 PM
  #59
PJmak's Avatar
I had a constant loud whine on my c55 from the moment i start the car until I shut it off. It was dependant on the revs too.
just checked my idler pully and it was a bit loose. Replaced the pully and the whine went away completely.
10 minute job.
Old Apr 30, 2018 | 06:13 PM
  #60
rilonprime's Avatar
2005 C55 AMG
10 minute job.
Just got my C55, and I have the same issue. Will try this and share what happens to me.
Old Feb 20, 2019 | 02:09 AM
  #61
rilonprime's Avatar
2005 C55 AMG
Bringing up this thread to see if anyone's fixed the issue of the engine/tranny whine on startup.
It is DEFINITELY not the air pump. It's not the idler pulley, and it's not the power steering pump.
Old Feb 21, 2019 | 05:01 PM
  #62
kjb55's Avatar
I've given up on trying to figure it out and I agree it's none of the suspects you listed. I'm leaning towards the oil pump as some have suggested.
