Outside Temp
2001 C32 AMG
Outside Temp
For about a week my outside temp is reading 85degrees celcius constant. I don't think the sensor has been dislodged as the temp is constant, am I missing something simple here?
It is just the sensor needs replacing, if so where is the sensor located?
Cheers
Cheers
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
2001 C32 AMG
Does anyone know if the comand fan delay going off has anything to do with the outside air temp?
If my sensor is reading 85degrees by default maybe this is why my comand fan is not turning off? Or is that a different issue and I need to update my comand/put in a bypass switch?
Just would be funny/interesting if my battery drain and this temp busted could be related somehow..
2001 C32 AMG
This thread I just found actually might have the answer.. I had ripped part of my front bumper off a while back, my mate put it back on perfect but this may have become unplugged in the process..
http://www.benzworld.org/forums/w203...5-degrees.html
