Help with oversize pistons.
Please help - I am desperate!
Comments please?
Comments please?
Here's a quote from a post I did a while back and some links:
a lot cheaper and potentially faster than a C63 with 500hp.
You may have a difficult time reading this website, but take a look at it. I believe this is a C32 estate that has gone with the m112 3.7l block and heads and retained the C32 supercharger and other components. He used a 58mm supercharger pulley and a 182mm crank pulley and he's almost at 1.4bars. He also used pistons and rods from the m113k engine and the c55 exhaust. He's claiming 500hp and it sounds like it could be possible, but you never know. Take in mind it has been translated from Chinese to English, so it may not make a lot of sense.
http://babelfish.yahoo.com/translate...rUrl=Translate
Here's another cool link that has a c32 with a m112 3.7l engine and different supercharger.
http://translate.google.com/translat...ews%2F12%2F325
If I remember correctly, you may need to switch some pins around in the harness to make it work correctly. Apparently the 80mm throttle body opens in the opposite direction and you need to switch certain pins to make it open in the correct direction. Take a look at this link, it should be the info you are looking for: https://mbworld.org/forums/w211-amg/...-04-cl600.html I think that the sc inlet is from the E55, take a look at some pics of the one I bought recently. You will see the part number on the inlet.
Here is the link to the thread that I made: https://mbworld.org/forums/c32-amg-c...dy-thread.html
You can also put in larger pistons, although that would probably cost more.
