AMG Sway bars / brabus sway bars??
Old May 14, 2003 | 11:50 PM
jleung88's Avatar
Question AMG Sway bars / brabus sway bars??
Does the C32 come standard with sway bars? If not, is it worth putting in some?
If it does, why do I feel that the car isn't very stable when cornering?
thanks!!!
Old May 15, 2003 | 12:07 AM
SiLvaC32's Avatar
C32
it does come with sway bars... but you can always upgrade to bigger bars. you feel the car is not stable is probably due to the center of gravity is sittin up so high. which causes more body roll
Jerry
Old May 15, 2003 | 03:39 AM
xS3x's Avatar
2002 330Ci
the sway bar will not lower the center of gravity of your car. aftermarket sways tend to be thicker than the OEM sways to reduce chassis flex under cornering, thus giving you less body roll.
lower it if you feel its not stable..
