what is the diff between malfunctions and CELS? how do you read malfuntions?
But...
I was hoping omeone could explain malfunctions to me better. How do you read them? Or get the code for em? What's the difference between malfunctions and CELS?
TIA
Ps. doea anyone know anything about mecedes emission readiness parameters? Are they based on miles, ignition cycling, tempurature cycling or perhaps others?
I know every so often I'll get an ESP malfunction, but it then goes away. I swear sometimes I think these cars have a mind of their own.
There are "current codes" and "stored codes". Stored code is like your ESP mulfunction that then goes away. But the code is still stored in memory for the mechanic to read later. And current codes are the ones that are still in effect. STAR system reads all of them. Most of the OBD scanners only read current codes. Things like ESP and BAS which have thier own indicator light dont result in a CEL (Check Engine Light).
And your car does have a mind of its own. It's called the ECU. Sometimes I wish that some of the newer members here (not you guys) had an ECU. Then maybe Jerry can be re-tune them.
It really depends which ones you're getting. The car considers everything a malfunction. When your fuel or wiper fluid is low or you have a light bulb out it shows up as a malfunction. I constantly have the "teleaid SOS" malfunction. No big deal in that case.
When the car is on you can cycle through any current malfunctions that may be present with your steering wheel buttons. cycle through until you see malfunctions then use the up/down button to cycle through the specific malfunctions.
http://www.devtoaster.com/products/rev/
