Start problem, changed out CPS. Found Fuel Pump Fuse was bad!?!
. I checked the fuses and found that the Fuel Pump fuse was blown. I replaced it and car started. I don't feel too bad as my car has 165,000+ on it and having a new CPS doesn't hurt. So what does a blown Fuel Pump fuse mean? From my search it is a sign that my Fuel Pump is going bad. Is this a correct assumption or is there any other possibilities?
. I checked the fuses and found that the Fuel Pump fuse was blown. I replaced it and car started. I don't feel too bad as my car has 165,000+ on it and having a new CPS doesn't hurt. So what does a blown Fuel Pump fuse mean? From my search it is a sign that my Fuel Pump is going bad. Is this a correct assumption or is there any other possibilities?If it blows again with anything more than a 1/8th of a tank then I would try a 25A fuse and if the problem is solved then no further action. If the 25A blows then you might be looking at a new pump unless you can find a wire that is intermittently chaffing.
