Hi,
My 2002 C32 AMG's LED on the side view mirror is broken although when I signal the light works. Anyone knows where I can buy the housing (for amber LED; not clear) so it will match the driver's side view mirror? Thank you,
Andy T
Andy T
Andy T
check on ebayOriginally Posted by andy T
Hi,My 2002 C32 AMG's LED on the side view mirror is broken although when I signal the light works. Anyone knows where I can buy the housing (for amber LED; not clear) so it will match the driver's side view mirror? Thank you,
Andy T
Quote:
+1, i'd try to find one that's already painted to your color of your car too. where did you find that sticker in your avatar?Originally Posted by C32Dan
check on ebay
All LEDs should be white but not clear regardless of color of automobile.
I think he's talking about the pre-2005 model. The older ones had the frosted lenses with the amber looking led's. You can get the part number off of the actual part and order it from parts.com. You can easily upgrade both sides for around $50 to the clear led version. I'll have to see if I can find the part number. Makes the car look so much newer.
ok just on ebay and pick one and change both left and right ther is an easy DIY on the W203 non amg DIy forum
