C55 battery drain
Old Jun 3, 2011 | 08:02 AM
Phil C55's Avatar
2006 C55 AMG White/Ash
C55 battery drain
I did a search but didn't come up with anything. I keep my car on a Optimate 6 battery tender and so it has never had a dead battery, but if it isn't on the tender, the battery drops fairly quickly. A few weeks ago I checked the output from the alternator and it was fine at 14v so that seems OK. I figured I would freshen up the original battery and bought a Mercedes factory correct battery and put it in. My tender is hard wired and so I plugged it in. As expected it was in float mode very quickly. I drove the car on Monday and didn't drive it since or plug it in either. This morning I went down and with my hand held battery tester it only showed 75%. It's back on the tender now and it's showing some amperage going to it, so the tester wasn't wrong. I know C32s had drain issues, but I haven't seen anything about C55. Thoughts on what to check???
Old Apr 7, 2014 | 08:56 PM
wizinator's Avatar
06 C55 AMG
Im new to the board.. and i realize this is an old post, but how did you make out with your issue?
