brake caliper clearance
2002 C32 AMG
My fellow owners,
Just got new 18" wheels/ Toyo HP tires for the C32. On the front, with 3MM spacers, I have about .5MM - 1MM clearance between the back of the wheel and the front of the caliper. Since the calipers are mounted firmly and are not on slide pins, is this enough clearance?![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
also, does anyone know the minimum recommended front dick thickness? Mine are a bit worn - probably 1.5MM wear on each disk surface.
