Strange C32 symptoms
Old Jul 5, 2011 | 11:13 AM
fccthawk's Avatar
2003 C32 AMG
My 03 c32 with 156k miles has developed some very strange symptoms over the past few weeks, maybe someone has seen these before and can help me out.
1) Clakity clak sound when I first start seems to go away after driving a little time. Valve? seems to be coming from the drivers side cylinder bank, but not sure.
2) rpm's will surge and then drop down just above stall, this has happened twice. The check alternator/battery light will come on but will go out once rpm's go above idle.
3) throttle response has acted up twice also. Step on the gas, delay then take off. After a few moments this also goes away.
No check engine light, or codes. Are the symptoms related? Otherwise the car seems to be running normally, I have not noticed any drop in performance. Not sure what to check. I am hoping the forum has some ideas.
Old Jul 7, 2011 | 02:10 PM
testknight's Avatar
CLS55
when was the last time you did maintenance? In particular your belt?
Old Jul 7, 2011 | 04:11 PM
fccthawk's Avatar
2003 C32 AMG
Belt is about 70,000 miles old. Oil changed 5,000 miles ago. Plugs also 70,000 miles old.
Old Jul 12, 2011 | 11:42 AM
fccthawk's Avatar
2003 C32 AMG
Along with the symptoms, finally got a check engine light, which reset itself after the allotted # of restarts with no faults. Pulled the following codes:
P0175, P0172 Bank 1 and 2 too rich. P0175 Map Sensor. With the above symptoms at the beginning of the thread, is the MAP sensor the problem or just a symptom?
Old Jul 19, 2011 | 05:02 PM
C32vsU's Avatar
2003 C32 AMG
I had the same problem with mine
brought it to my tech and he replaced the map sensor, good as new. Also i am not experience the weird 1500 rpm shift that has been talked about, but that could just be because of the reset that the mechanics did while fixing the other issue.
Old Jul 25, 2011 | 01:44 PM
fccthawk's Avatar
2003 C32 AMG
I have changed out my map sensor and have had no further problems.
Old Jul 27, 2011 | 11:40 AM
testknight's Avatar
CLS55
Thanks for reporting back, good to know
