Anyone replace their H/U with Cartronics?
The unit came from a request from the largest chain of MB dealers in the US. I can't say the name of the franchise, but it ends in nation. - Anyway, that unit came from a request to test certain units that came to market, and they did not fit the bill for reliability and function. We went to a manufacturer, and basically design spec'd a system. It is perfect for cars that do not currently have COMAND. If you have COMAND, we have some better options.
1. Cost - you would have to replace your amp and rewire at a minimum plus the COMAND PRO. Again, the COMAND PRO is a great solution if you do not have the HK amp already. So we can add about anything to your current COMAND for less and still retain all factory functionality.
2. Integration. Again, your current system (since it is the COMAND and not one of the lesser radios) has so many hooks and effects in the car, it would generally not make sense to take all that out. You don't really gain that much that can't be quickly added to your system.
It looks like I will lose the CD changer if I do the iTronic BT? Thanks!
The bluetooth has no effect on the changer, only iPod does.
The iTronic stuff would definitely be the best way to go. WAY money ahead (no amp change, no rewire, etc etc)
The iTronic is full digital and capable of reproducing whatever quality goes in. If it is 128kbps in 128kbps comes out. However, if you put in 320kbps CD quality iPod files, that is what you will get out
