C55, who has the most mileage?
I hear ya! I'm going to Knoxville today to trade my Corvette in on a new SS sedan (4 door Camaro basically) and I'm still going back and forth!
https://www.mbusa.com/mercedes/herit...ghmileageaward
https://www.mbusa.com/vcm/MB/Digital...leageaward.pdf
Not for me yet...129K miles on 2003 C32.
05 C55 had the 250k badge
87 300 D had 250K, 500K, and 750K when it got rearended and totaled.
02 SLK320 has the 250K and 500K badge about 50k miles away from 750K badge. (wifes daily driver)
Things that needed replacing so far:
48k miles: replaced crank position sensor
53k miles: replaced oil cap and valve cover gaskets
54k miles: replaced left front lower cross strut socket
67k miles: replaced left front wheel bearing, sensor for ABS was malfunctioning inside the bearing
81k miles: replaced bi-xenon headlights, both were turning pink
82K miles: brake fluid change, replaced both front cross struts, front suspension bushings, rear sway bar mounts, rear shocks, replaced left rear coil spring
84k miles: replaced brakes and rotors (lasted 36k miles since I bought the car)
85k miles: replaced battery
AND YOU TELL YOUR WIFE, well, tell her you love her or something, but we care. Seriously, don't **** off the wife. /fellow husband
1. Valve covers gaskets and other oil seals.
2. Plugs and wires
3. Mounts, transmission & motor
4. Cooling systems: Radiator, hoses.
5. Transmission: Fluid and filter and differential fluid.
6. Rear main seal
7. Starter motor
8. Suspension: Front and rear complete bushings and struts
9. Brakes: Rotors/pads & fluid flushing every 3 years.
10. Fuel Delivery: Fuel gauge float sensor
11. Alternator: Voltage regulator
12 Belts: Belt and Pulleys/Tensioners
That's about it, basically the maintenance on all of the powertrain parts.
Miss it.
