Coilovers and spacers
C55 AMG, E55 AMG
So I'm finally considering getting coilovers for my C55. I've done a lot of reading and narrowed it down to KW V2 or Bilstein PSS9.
Question is will I be needing spacers? If yes, how thick? I couldn't seem to find a definite answer on this. I know it's mostly offset dependent and my 19" Bremma's offsets are 32 front and 35 rear.
Also, one reason why I narrowed down my choices to the above two is that they are stainless, so I don't have to worry about rust issues during winter. But will they still suffer from getting stuck up from extreme cold?
Any other info I should know about having coilovers during winter? Not that my C55 will be daily driven in snow. It will probably be garaged 95% of the time. Just for those rare occasions when my wife has to use the SUV.
Was doing a search on the exact same thing the other day too. I saw some people had to shave part of the perch and some people were able to install fine without modifying anything
C55 AMG, E55 AMG
With the Bremmas having 32 ET up front, this would mean that I'll need at least a 5mm spacer right?
Does the C55 also have "special" spacers? And where's the best place to purchase them?
Thanks again for your help.
108-142-685 lbs/in and the H&R 29367-3
and 29313-1 are 52 N/mm=297lbs....working/static rates
Thanks! Saw the thread you bumped. There you said: "You need around et 27 to clear the perches on any set of coil overs. Your rear offset is fine."
